1988 Nissan Truck Ign Coil
LARRY DANLEY
1988 Nissan Truck 4 cyl Two Wheel Drive Automatic
This truck has no spark to start .
I pulled the 2 wires with clip from the coil and I check
For power when you turn on Ign.
We have power .
I pulled Coil wire from distb. and Ground it out to frame and cranked engine
Still no spark . I check coil wire it is good .
To me we have bad coil .
Do I need to check Ground wire from coil wire plug to
+ post on battery to see if we have ground.
Oct 20, 2010 at 2:56 PM
  • 75,988 POSTS
Check and test the coil, ignitor and distributor pick-up coil
Oct 20, 2010 at 4:28 PM
