Engine Performance problem
1988 Nissan Truck 4 cyl Four Wheel Drive Manual 139k miles
Hi, been fighting a problem on this old truck with it wanting to bog/sputter as soon as you get into the accelerator alittle bit. Already changed fuel injectors (TBI) and did complete tuneup. suspect insufficient fuel pressure. I want to install an inline fuel pressure regulator that works off of vacuum and has an inline hose connection for in/out AND is ADJUSTABLE so I can set the pressure window for idling and hi-load. The factory one is not adjustable. Can you recommend where I can look for one like I described above? thanks.
Jun 14, 2010 at 5:54 AM
