1987 Nissan Truck clutch problem
1987 NISSAN TRUCK
120,000 MILES • 4 CYL • 2WD • MANUAL
MARKLED
My truck was doing fine. Then this morning I couldn't push the clutch pedal in. I reached down behind the pedal and pressed the button that would allow the truck to start and started it. I can shift into all gears, but it's as if it were still in neutral. I can't find anything broke visually. Can you help me?
Aug 22, 2010 at 2:35 PM
Sounds like its slipping to me, it needs a new clutch assembly
Aug 22, 2010 at 2:43 PM
