1987 Nissan Truck
CROSSFIRE69
  • 1987 NISSAN TRUCK
Shakes or Wobbles problem
1987 Nissan Truck 4 cyl Four Wheel Drive 230000 km
have a vibration between 65km and 85km, tried tires, shocks, balance drive shaft (hose clamps), changes under load and bumps, feels like a bent rim but it's not, ran it up on hoist rear drive shafts seem true wheel and axles run true, u joints move freely, pinion no noise or movement, center bearing good and has been replace before, but noticed not much movement available to compensate for drive line length movement, know two other people with same problem, however shocks did improve the problem a fair bit, someone told me that these trucks have weak rear springs that cause it to bounce, have you ever come across this? Thanks Axle
Saturday, July 24th, 2010 AT 11:24 PM
  • 31,937 POSTS
Hi there,
If this is a body vibration it will be from the rear end, tyres, rims, drive shaft suspension, you will have to work through reach to isolate the problem, check the spring height for each rear spring, if one is a lot lower this may be your problem, measure from the top of the wheel each to the ground.
Mark (mhpautos)
Sunday, July 25th, 2010 AT 1:44 AM
