1986 Nissan Truck fuel injectors
1986 NISSAN TRUCK
160,000 MILES • 4 CYL • 2WD • MANUAL
PAGECOUNTYMALE
  • 6 POSTS
Cranks over, won't start. It is 86 D21, z24 engine cranks but no start. Has fuel pressure into throttle body, but it's but still won't start, it was running and just died. Also have fuel in the return line. Iam lost, tried changing throttlebody,emc computer,fender mounted relays for fuel pump, but still won't start.
Nov 21, 2009 at 8:59 AM
Do you have spark? if so check the fuel pressure if its within specs and injector/s pulsing
Nov 21, 2009 at 3:10 PM
