1986 nissan truck fuel filter
1986 NISSAN TRUCK
DONNYLM1958
I have a 1986 nissan king cab truck 720 series with 2.4 negine with 179,000 miles.I cannot locate the fuel filter. Dealer says it should be on the firewall but it isn't.Can someone please help!!!!!
Jun 20, 2006 at 10:46 AM
SKIPATROLER
I have a 95 pickup and the filter is on the left side of the engine compartment basically under the air filter. you should see one rubber tube coming out of the top going toward the carburator and then the feed line comes up from underneath.
Sep 13, 2006 at 8:22 PM
DUG
I have the same truck in a 4x4. I looked and I don't see it either. Try locating you fuel lines and trace them from the trottle body to the tank or start at the tank and go to the engine. The book I have says its a canister type located in the engine compartment. Good luck.
Nov 8, 2006 at 5:47 PM
DUG
I traced my fuel line and found that it is posibly in front of the right rear wheel. There is a bracket that is protecting it with what looks like the fuel pump. Hopefully yours is set up the same.
Dec 4, 2006 at 7:23 PM
