HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Truck
Engine
Symptoms
Runs Rough
1986 Nissan Truck Engine
QUAYLT
MEMBER
1986 NISSAN TRUCK
4 CYL
2WD
MANUAL
132,000 MILES
Truck runs rough like it is missing. I changed the spark plugs and wires a month ago. It just started doing this a few days ago.
Tuesday, August 31st, 2010 AT 9:18 PM
MECHANIC
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
SPONSORED LINKS
Saturday, September 4th, 2010 AT 6:39 AM
Please
login
or
register
to post a reply.
Related Engine Runs Rough Content
1986 Nissan Truck 720 Truck Runs Rough
My 1986 720 Series Truck Runs Rough At Idle And Surges/stumbles At Mid-range Rpms. The Engine Vacuum Is Good With No Vacuum Leaks. The...
Asked by
bnmdeer
1 ANSWER
1986
NISSAN TRUCK
VIDEO
Code Read Retrieval/Clear
Instructional repair video
GUIDE
Check Engine Light
Why is my check engine or service engine soon turned on? In this guide we talk about what this is associated with this notorious light, what it is used for and what you...
86 Nissan Truck With Z24i Runs Rough At Idle And...
Put New Dist, Wires Timing Set Plugs
Asked by
jlawrence39
1 ANSWER
1986
NISSAN TRUCK
Running Rough And Reading A Code Of P0180
I Have A 97 Nissan Xe Pickup And My Vehicle Is Running Rough And Reading A Code Of P0180 (fuel Temp Sensor). I Noticed My Mpg's Dropped From...
Asked by
jchavis726
1 ANSWER
1 IMAGE
1997
NISSAN TRUCK
1990 Nissan P/u Se-v6 Running Rough
Past 2 Years, Intermittent Problem. Truck Runs Great For Months Then Begins To Sputter And Run Rough, Especially Noticeable Up Hill....
Asked by
Kingrichie
1 ANSWER
1990
NISSAN TRUCK
Vehicle Runs Fine With At Least A Little Throttle But...
My Friend's Son Drives A 95 Nissan Truck To High School. He Says That It Runs Fine With A Little Pedal But Runs Really Rough At Idle. I...
Asked by
flynpa
1 ANSWER
1985
NISSAN TRUCK
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear Mercedes Benz
Code Read Retrieval/Clear Honda
Online car repair manuals
