1985 Nissan Truck Tires Toed
1985 NISSAN TRUCK
NISSAN-CONFUSED
  • 8 POSTS
Steering problem
1985 Nissan Truck 4 cyl Four Wheel Drive Manual
1985 Nissan 720, 4x4. Tires are toed in badly, squeals on every corner. Help?
Dec 5, 2009 at 6:02 AM
BLACKOP555
  • 10,386 POSTS
what has recently been done to the vehicle? when did you start to notice this.
Dec 5, 2009 at 8:47 AM
NISSAN-CONFUSED
  • 8 POSTS
Just bought couple days ago, didn't really notice it until I got it on the freeway and couldn't control it around 50-65mph. I heard something about shims on the upper A-Arm but I'm not for sure...
Dec 5, 2009 at 11:37 AM
BLACKOP555
  • 10,386 POSTS
sure its toe and not a camber/ caster issue. if its on the control arm it wouldnt really affect toe. they are more for camber and caster.
toe is adjusted by turning the tie rods. can you get me a picture of the front end?
Dec 6, 2009 at 6:08 AM
NISSAN-CONFUSED
  • 8 POSTS
https://images.2carpros.com/forum/automotive_pictures/444192_tireguide2_460x0w_1.jpg
It's currently disassembled this picture is what my problem is. Sorry it took so long, been busy. How do I adjust camber?
Dec 12, 2009 at 10:22 AM
BLACKOP555
  • 10,386 POSTS
you have to use shims between upper link spindle and upper link bracket.
Dec 12, 2009 at 10:51 AM
NISSAN-CONFUSED
  • 8 POSTS
Upper link spindle and upper link bracket?
I'm not sure what you mean.
Dec 12, 2009 at 11:05 AM
BLACKOP555
  • 10,386 POSTS
upper part of your suspension upper spindle link and upper spindle bracket. look for the spindle youll see bolt. you put the shims there.
Dec 12, 2009 at 11:06 AM
NISSAN-CONFUSED
  • 8 POSTS
Thanks a lot. I got it figured out.
Dec 12, 2009 at 11:14 AM
BLACKOP555
  • 10,386 POSTS
no problem. but remember when you change caster camber will change too.
Dec 12, 2009 at 11:22 AM
NISSAN-CONFUSED
  • 8 POSTS
Well I thought I figured it out, though I can't seem to get the tires straight. Can you explain what caster is? Thanks.
Dec 12, 2009 at 4:06 PM
BLACKOP555
  • 10,386 POSTS
helps vehicle corner and wheels straighten out after a turn. negative is when the tops of the wheels are in more then the bottom. positive is the opposite. is yours negative or positive.
Dec 13, 2009 at 3:14 AM
NISSAN-CONFUSED
  • 8 POSTS
Positive, I've been doing trail and error with shims. It's getting old doing this process over and over haha.
Dec 13, 2009 at 6:53 AM
BLACKOP555
  • 10,386 POSTS
if its positive your going to want it to come in as much as possible.
Dec 13, 2009 at 7:41 AM
NISSAN-CONFUSED
  • 8 POSTS
Took a little trail and error with the shims, you've been a great help, got everything aligned thanks!
Dec 13, 2009 at 8:21 AM
BLACKOP555
  • 10,386 POSTS
no problem. am here to help. glad to hear you got it fixed and thanks for the feedback.
Dec 13, 2009 at 10:35 AM
