1985 Nissan Truck Possible timing chain issue
1985 NISSAN TRUCK
135,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOLSON123
My son just bought this w/Z24 motor. It ran really bad, and did a tune up w/ several leaking vaccum lines. During the timing procedure we couldn't get the mark to come up to the timing plate. It's about a 1/4 of a rotation off. Checked the roter in relation to where No. 1, and it's on the money.
The book we have makes note of the cam gear and pin location. I have a feeling the cam gear may have been installed wrong. I checked the dist. & it can only be positioned in one location. When I checked to see if the dist had been set wrong, I put my finger over the hole till it blew, and the same thing happened. The rotor was in position, and crank mark was a 1?4 rotation off.
Would you have some more info. I won't be back on till 5:00 pm PST
Mar 19, 2010 at 1:38 AM
RACEFAN966
  • 5,029 POSTS
Have you checked to see if the harmonic balance slipped. See the balancer has a rubber cushin between the center hub and the outer balancing ring. When the rubber goes bad it allows the outer ring to slip.
Mar 19, 2010 at 3:19 AM
JOLSON123
How do I tell if the alignment is off? I don't know how to tell if it's slipped.
Thank you!
Mar 19, 2010 at 10:21 AM
RACEFAN966
  • 5,029 POSTS
Can you include a pic of it? I will look it over and see.
Mar 20, 2010 at 3:46 AM
