1985 Nissan Truck leaking carburetor
1985 NISSAN TRUCK
123,000 MILES • 4 CYL • 2WD • MANUAL
JOEPRESKE
have 1985 nissan pick up with carburetor leaking gas on top at air fuel mix solenoid. how tight should screw on top of solenoid be. it has been tightened about a full turn to not quite "wrench tight". leak has stopped but am wondering if that is too tight to where heat may build up cause a failure in whatever seal there is there and cause another leak.
Jun 27, 2010 at 4:35 AM
  • 31,937 POSTS
I would not tighten this any more, if the leak continues i would be re building the carby.
mark (mhpautos)
Jun 27, 2010 at 7:22 PM
