have 1985 nissan pick up with carburetor leaking gas on top at air fuel mix solenoid. how tight should screw on top of solenoid be. it has been tightened about a full turn to not quite "wrench tight". leak has stopped but am wondering if that is too tight to where heat may build up cause a failure in whatever seal there is there and cause another leak.
Jun 27, 2010 at 11:35 AM
