1985 Nissan Truck Elect. fuel pump
1985 NISSAN TRUCK
SENGDAN
1985 Nissan Truck
Engine was losing power erratically; now not running at all. there is no power coming to the fuel pump, although the fuses have been checked and replaced. pump runs when wired direct from battery, as does engine, and seems fine.
Will running a new, fused line from a switched (from ignition switch) connection to fuel pump be safe?
or,
Am I overlooking a cutoff safety with reset, and, if there is one where is it please?
Thanks, Dan
Apr 22, 2010 at 3:01 PM
RACEFAN966
  • 5,029 POSTS
Have you checked the fuel pump relay to see if it is working?
Apr 23, 2010 at 3:11 AM
