1985 Nissan Truck
250,000 MILES • 4 CYL • 2WD • MANUAL
MEEKER15
i have a 85 nissan truck. it has 10 plug wires and a dual carb. my problems that i have is that when its cold it doesnt like to idle. and sometimes when i go full throttle is spits and sputters. what do i do?
Aug 5, 2010 at 2:38 PM
  • 31,937 POSTS
Hi there,
these engine have a problem with the cold idle set up, and they can burn out rotors and distributors, have the leads been disturbed, as they are set up as a leading and trailing firing system, inlet then exhaust plugs, the testing is long and some what complex for the cold start and mixture set up, but often a coolant temp sensor will be at fault, as the ECU may be thinking that it is warm already on cold starts and the air by pass is not open.
Mark (mhpautos)
Aug 5, 2010 at 9:54 PM
