1984 Nissan Truck Engine Stops Abruptly
220,000 MILES • 4 CYL • 2WD • MANUAL
JARASA2010
Hi, My truck is a 4 cyl with 8 spark plugs. I think it is callled a z24? I replaced the electric fuel pump because I thought that was the problem. It will start and run fine for a while (30 minutes) then it just stops. I have taken it my mechanic many times over the years but he is baffled. He suggested getting a carburator from a junk yard. What do you think is making it kill all of a sudden?
Feb 24, 2010 at 5:01 PM
CARSANDAIRPLANES
  • 19 POSTS
You may have a heat source that is too close to the fuel line causing vapor lock. If you can find such a problem, fabricating a heat shield may fix the problem. Does this happen all year round?
Mar 13, 2010 at 5:23 PM
