1984 720 headlight and parking lights problem
720_250K
1984 720 truck, Z motor, 2WD with 260K miles.
I have two problems:
first - Parking lights will not turn immediately on with switch. Delay varies with outside temperature. Anywhere from 5 seconds when warm to 10 minutes when winter. Brake lights will light up and blinkers will work immediately however.
second- Headlights low beams will now only work with high beams switched on.
I have been checking the end sockets for corrosion but have found very little (cleaned and electrolyte pasted). I believe either have a short/break somewhere or maybe a failing combi switch.
(Combi switch I believe is the one on steering column if I got the name right). Any ideas to shorten the search? Much appreciated.
Nov 20, 2007 at 5:02 AM
2CARPRO JACK
  • 11,533 POSTS
I do know those combo switches fall apart like crazy, replaced many of them.Does your truck have high and low bwam relays for the headlights? If so use a test light and check for power trigger at the low beam relay with the lights on.
Nov 20, 2007 at 6:50 AM
THOMAS BYRD
I have the exact same delay problem on my running lights. Exactly as stated above, the delay is much worse when the weather is colder. possibly a relay problem?
Dec 7, 2016 at 10:06 PM
