I am stumped. Any ideas you could throw my way would be greatly appreciated
1994 Nissan Sentra MAF Code 12
It would be unlikely that diesel had gotten into the intake manifold. If it had the motor would have smoked for a while.
The problem of building and using a consult cable is that I then will want to tinker with the ECM to change the performance to what I want. Because I am good with both computers and electronics this would not be the best option for me.
When I get the new new MAS, I will get back with you. In the mean time: what is your experience with the failure of ECM's; rare or common? Do you know of a quick test I could perform to determine if the ECM has failed and is pulling the MAS signal voltage down? And finally, in this model/year of car, do you know what the relationship between fuel/air/injector timing is to MAS signal level? The reason for this last question is because I used a battery and potentiometer to apply 1.0 volts to the MAS signal line and the car stalled.
Now at wits end and may have to build my consult cable to do what I paid the dealer to do - put the car on a computer and give me a copy of the print out.
Do you think that the manufactures claim of "Only a Nissan part will work?" Second, when I pay a dealer to do a computerized diagnostic, just how do I get them to do it?
1. Can you give me ideas of what to look for? 2. Could an O2 sensor create this problem?
Thank for the help.
Suggested Repair
After confirming the MAF signal stays low (about 0.23-0.25 V versus the 0.7-1.1 V spec) with a known-good sensor and that the signal circuit is being pulled down toward ground, replace the ECM. Also check MAF wiring resistance, reference voltage, and the O2 sensor, which can send false mixture data if shorted or contaminated.
Conversation Summary
A 1994 Nissan Sentra developed hard starting, stalling, rich running, and a persistent code 12 after an oil change and diesel crankcase flush. MAF signal voltage stayed far below spec even with replacement sensors, and the car ran poorly when the correct voltage was forced onto the signal line. Wiring checks and dealer tests did not resolve it. The owner later found the MAF signal circuit shorted toward ground and replaced the ECM, which restored normal running and also stopped an intermittent transmission sticking issue.
