1996 Nissan Sentra P0400 EGR Code
LADDOOSINGH
I have NIssan sentra 96 with 100 K miles on it. The engine cehck light comes up quite often with PO400 code which means EGR overflow malfunction.
There is no prblem as such while driving.what should I do ? :(
Feb 28, 2006 at 8:48 AM
FISHERMAN
  • 937 POSTS
The EGR stands for Exhaust Gas Recirculation.
Exhaust gas is routed back into the combustion chamber because the exhausted air is much hotter than the intake air, By sending warmer gas into the combustion chamber, the air/fuel mix does not have to do as much work to heat up, and your engine runs more efficiently.
the reintroduction of exhaust gas will cause a very rough idle and can
cause stalling if to much is introduced into the combustion chamber
do you have that rough idle?
Mar 1, 2006 at 1:38 AM
BANHBOXEO
I have the same trouble code 0400 on my maxima99 do you have the picture of the part need to be replace
thank you
Jun 24, 2006 at 2:16 AM
SCOTT BRANNAN
I am having the same problem with my 96 Sentra. I have 150,000 miles, and I have tried almost everthing. I have gone throught my Haynes book trying to find any info, but nothing is there.
I can not get my car inspected with the light on. What do I need to do next?
Thanks in advance to anyone that can help.
Scott
Aug 27, 2006 at 1:38 PM
FISHERMAN
  • 937 POSTS
Have your EGR valve check and replace it,
if necessary.
your check engine light must be off to bhe smog checked.
Aug 28, 2006 at 1:18 AM
Suggested Repair
Have the EGR valve checked and replace it if necessary. The check engine light must be off before a smog inspection.
Conversation Summary
The owner of a 1996 Nissan Sentra with about 100,000 miles reported a recurring P0400 code for an EGR overflow malfunction, with no drivability problems. An expert explained that the EGR system recirculates exhaust gas and asked whether the engine had a rough idle. Other owners reported the same code on a 1999 Maxima and a 1996 Sentra that could not pass inspection with the light on. The expert advised having the EGR valve checked and replaced if necessary, noting that the check engine light must be off for a smog check.
