1999 Nissan Sentra Brake Grinding
FALCONPLUMBER
I have a '99 Nissan Sentra 99,000 miles. I recently changed the brake pads and rotors (front) and there is a grinding sound coming from the left wheel when brakes are applied (audiable at low speed). And there is also a low scraping sound, when driving, from the right wheel (audiable at low speed). I took both wheels apart again and found no sign of rubbing from any other metals but one pad on the left wheel seems to be wearing unevenly. Maybe poor manufactufing. Can you explain to me the nature of the problem? Did I do something wrong? The brakes do work well.
Richard
Dec 18, 2006 at 7:06 AM
  • 75,988 POSTS
Might be your caliper binding or the brake hose acting as a check valve on that side.
Mar 13, 2021 at 11:05 AM
FALCONPLUMBER
Thank you for your reply. How would I fix the problem? I bled the brakes when I installed them, If that has anything to do with it. Do I have to replace the caliper?
Richard
  • 75,988 POSTS
Either you replace it or its time to learn the how to.
The caliper piston is self adjusting -Note when the vehicle starts moving the contact between the rotor and inner pad will push piston back and thru the help by the seal .Inspect the brake hose
Suggested Repair
Inspect the brake hose and caliper on the noisy side. A binding caliper or a hose acting as a check valve can cause uneven pad wear and grinding. Replace or rebuild the caliper if the piston does not retract, and replace a restricted hose.
Conversation Summary
The owner of a 1999 Nissan Sentra with 99,000 miles replaced the front pads and rotors, then heard grinding from the left wheel when braking and scraping from the right wheel while driving at low speed. One left pad was wearing unevenly, although the brakes still worked. The expert suggested a binding caliper or a brake hose acting as a check valve, and advised inspecting the hose and replacing or rebuilding the caliper if the piston is not retracting.
