Car start when jumped but shuts off when jumper cables are removed.
Or shuts down a few seconds later when jumper cables removed.
It stays running because its being powered by the giver(the other car). Recommend you inspect, clean and test every connections from the battery positve terminal to starter, from battery negative to engine and engine to firewall to include firm connection behind the Alty
Sunday, December 31st, 2006 AT 11:58 PM
