2006 Nissan Sentra serpentine belts
WCOUS2
  • 2006 NISSAN SENTRA
  • 4 CYL
  • FWD
  • 42,000 MILES
Speaking to a simple minded person, how tight are the belts suppose be?
Tuesday, February 3rd, 2009 AT 5:43 PM
OBXAUTOMEDIC
  • 3,711 POSTS
If it is a 2.5L engine there is a tensioner assembly and the tension is adjusted automatically. However, there is a possibility that the tensioner is bad. Also, if you are hearing a squealing noise from your belt it is also possible that the tensioner pulley bearings are going bad. One way to find out is to take a can of wd40 or similar and with engine off spray center bolt of tensioner, start vehicle if squealing is gone for short period then replace pulley.
If it is a 1.8L engine it has an Idler pulley and same could be wrong with it as far as the bearings. Do the same test as above to check bearing.
Tuesday, February 3rd, 2009 AT 5:58 PM
