HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Sentra
Engine
Serpentine Belt
1995 Nissan Sentra putting on alternator belt
CARYLWOMBLE
MEMBER
1995 NISSAN SENTRA
Other Category problem
1995 Nissan Sentra 4 cyl Front Wheel Drive 19500 miles
I am trying to put on an alternator belt and I cannot find the adjustment to put the belt on.
Friday, January 4th, 2008 AT 4:36 AM
MECHANIC
The adjuster is behind the alternator you loosen that to include the lower bolt then slide to the side.
Friday, January 4th, 2008 AT 5:37 AM
Please
login
or
register
to post a reply.
Related Serpentine Belt Content
2006 Nissan Sentra Serpentine Belts
I Am Putting New Belts On Can Not Find The Lock Bolt On The Front Belt If There Is One. Also In Laymen Terms How Tight Should The Belts Be?
Asked by
wcous2
1 ANSWER
2006
NISSAN SENTRA
Speaking To A Simple Minded Person, How Tight Are The Belts Suppose Be?
Asked by
wcous2
1 ANSWER
2006
NISSAN SENTRA
Engine Wiring Diagram
Wiring Problem, Where The Signal To The Brain That Need Wiring Diagram Fuel Supply To The Engine For Can Find The Wiring Diagram For The...
Asked by
Anonymous
4 IMAGES
1995
NISSAN SENTRA
1995 Nissan Sentra Timing Belt
Does A Blown Timing Belt Mean That The Engine Is Gone?
Asked by
downes24
1 ANSWER
1995
NISSAN SENTRA
1995 Nissan Sentra Adjusting Idle
Engine Performance Problem 1995 Nissan Sentra How Do You Adjust The Idle?
Asked by
dalegates51
1 ANSWER
1995
NISSAN SENTRA
VIEW MORE
Serpentine Belt Replacement Ford
Serpentine Belt Replacement Chrysler
Serpentine Belt Replacement Ford Explorer
