2003 Nissan Sentra Not firing over
RWHITE45
  • 2003 NISSAN SENTRA
Engine Mechanical problem
2003 Nissan Sentra 4 cyl Two Wheel Drive Automatic 63k miles
THe car cranks but does not fire. I get no ignition, what do I try to find out what it needs? Does it have an ignition coil and if so where is it located?
Monday, September 20th, 2010 AT 3:29 PM
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Monday, September 20th, 2010 AT 11:50 PM
