2003 Nissan Sentra engine light soon
ALCACEV
  • 2003 NISSAN SENTRA
Engine Mechanical problem
2003 Nissan Sentra 4 cyl Two Wheel Drive Automatic 90.000 miles
took my car to auto parts was scan /problem is fuel level sensor a level circut low input code p0462. Want to know is it a serious issue how long can I drive with light on. What will be the charge to fix this problem.
Monday, March 8th, 2010 AT 1:41 PM
LEGITIMATE007
  • 5,121 POSTS
Fuel level sensor, is basically the "float" on the fuel pump, basically your gas level indicator will be incorrect. But other than that, you should be able to drive until you decide to have it fixed, you will need to replace that part on the fuel pump. Couple hundred dollars
Monday, March 8th, 2010 AT 2:31 PM
