1999 Nissan Sentra car dieing
JNR420
  • 1999 NISSAN SENTRA
  • 4 CYL
  • FWD
  • MANUAL
  • 180,000 MILES
My 99 nissan sentra manual front wheel drive 4cyl will run fine for a while then it just suddenly dies it will sit and turn over and keep turning over but will not start if someone pulls the car and we pop the clutch it will start back up
Friday, July 9th, 2010 AT 2:48 PM
Its very strange for it to start up when you pop the clutch and unable to when using the key and cranking it over and it will not start. Sounds like an ignition switch but Do below 1st and get back with me
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Friday, July 9th, 2010 AT 3:06 PM
JNR420
Gettin plenty of fire it starts and runs fine for a while then just dies unexpectedly
Friday, July 9th, 2010 AT 9:27 PM
Check the fuel pressure to rule out the fuel filter and the fuel pump and test the ignition switch
Friday, July 9th, 2010 AT 10:11 PM
