An small oil leak started 4 months ago and got progressively worse to no longer driveable. It's near the front wheel on passenger side. Appears to come from right side engine but not easy access to see/check due to belts/parts and area is recessed. One mechanic said the motor would have to be pulled to repair it. Another said it might be the front seal and motor would not have to be pulled. Cost to pull engine is prohibitive. Any suggestions?
Aug 27, 2008 at 9:45 AM
