1994 Nissan Sentra engine/oil leak
THEGMEN192
  • 1994 NISSAN SENTRA
  • 4 CYL
  • 218,000 MILES
Recently I acquired a 1994 nissan sentra with 218,000 miles. I just replaced the exhaust (that costed me over 900 dollars) and I realized there may be an oil leak. When I shut the car off there is smoke coming from the engine. There is a fluid, possibly oil around the upper part of the engine and along the left side near the alternator. The last few days the car seems to be running hot. Could the over heating be due to an oil leak? The heat in the car does not get hot either. Even if the car has been sitting all night the temp gauge says the car is warm as I start to drive the gauge rises and the next thing I know it is at "H". I turn the heat on full blast to try and cool down the engine and the heat finally works. Well because the car is going to over heat of course. What is going on? And another thing when I try to make a turn either left or right it feels like when a car stalls out and you cant turn.
Tuesday, January 13th, 2009 AT 11:17 PM
ZACKMAN
  • 4,202 POSTS
You have two separate problems.
Oil leak: If it is coming from somewhere the alternator is, you have a bad seal. It will be either one of the camshaft seals or the front seal (crankshaft seal). You won't know until you pull the harmonic balancer out (crank seal) or the timing cover (for the cam seal).
Overheating:
You said it would cool off if you turn the heater on. Your thermostat is stuck closed. Replace it.
Friday, January 16th, 2009 AT 1:49 AM
