P0420 Catalyst System Efficiency Below Threshold (Bank 1)
Code P0420 may mean that one or more of the following has happened:
Leaded fuel was used where unleaded was called for
An oxygen sensor is not reading (functioning) properly
The engine coolant temperature sensor is not working properly
Damaged or leaking exhaust manifold / catalytic converter / exhaust pipe
Retarded spark timing
The oxygen sensors in front and behind the converter are reporting too similar of readings
P1448 -Evaporative Canister Vent Control Valve
Check the EVAP vent control valve
The fuel pump is in the fuel tank
SPONSORED LINKS
Friday, October 30th, 2009 AT 11:28 AM
