1998 Nissan Sentra Car won't turn over
JUANITAHASTINGS
  • 1998 NISSAN SENTRA
  • 4 CYL
  • FWD
  • 145,000 MILES
Just replaced the head gasket, had the head shaved, car turns over and sounds like it'll start but doesn't. Replaced spark plugs, getting spark, and getting gas to the spark plugs. Just cannot figure out what is missing. Battery is strong.
Monday, August 18th, 2008 AT 8:33 PM
Did you put the engine no.1 piston on its compression stroke and rotor pointing to no.1 cap tower when you installed the distributor-
Sounds like the valve timing is off check the cam and crank alignment-
Wednesday, August 20th, 2008 AT 1:40 PM
