1997 Nissan Sentra Nissan wont start
FAVOURED1
  • 1997 NISSAN SENTRA
  • 4 CYL
  • FWD
  • 94,000 MILES
My car wont start it turns over but wont start battery I just got about 4-6 months agoi replaced alternator about 2 months ago but prior to this for about a week the car had smoke coming from the engine it wasnt running hot but smoking and it sounded like a grinding sound when I crunk it up
Monday, October 11th, 2010 AT 7:03 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Monday, October 11th, 2010 AT 7:09 PM
