2004 Nissan Quest window
2004 NISSAN QUEST
RICHARD21093
Electrical problem
2004 Nissan Quest Front Wheel Drive Automatic 99000 miles
Power widow on drivers side stopped working
Jun 28, 2009 at 4:35 PM
BUDDYCRAIGG
  • 2,262 POSTS
remove the inner door panel so you have access to the motor on the window regulator.
have someone push the button on the switch while you check for power to the motor.
if you have power then it's most likely the regulator,
if you do not have power, then it's most likely the main switch.
Jun 28, 2009 at 5:17 PM
