1999 Nissan Quest Sevear loss of oil
1999 NISSAN QUEST
TRAVIS COILE
1999 Nissan Quest Front Wheel Drive Automatic
After a oil change on my wifes nissan quest the check engine light came on then the engine quit. After further inspectiion I found large amounts of oil in the drive way and where it had quit.Could the oil pressure switch malfunction and cause the engine to pump out the oil ?
Apr 18, 2009 at 9:51 AM
MERLIN2021
  • 17,250 POSTS
Normally it's impropper oil filter installation, either wrong part number, or old "O" ring seal still against filter mounting surface. Remove the filter and check for an extra seal!
Apr 18, 2009 at 9:57 AM
