Engine Mechanical problem
2003 Nissan Pulsar 4 cyl Front Wheel Drive Manual
Hi!
Was hoping someone could help me out. Recently my car was serviced at home and after changing the fuel filter, the car would not start. I had someone come out and look at the car and they performed a bench test on my fuel pump. They advised there was an intermitent fault with the fuel pump where it would fail maybe 1 out of 5 times, therefore we have since put in a new fuel pump.
Still had no luck starting the car. The pump will prime for a few seconds and seems to be getting the fuel to the fuel filter, so there seems to be a problem after this point.
When trying to start the car, the car sounds like it is about to start, but just won't turn over.
I was hoping someone could suggest what I could try from here? Or have any ideas of what could be wrong?
Thanks!
Thanks for your help :)
I was under the impression that the fuel filter for a 2003 pulsar could only be fitted one way?
Also, I have checked the fuel lines near the engine and there is no fuel reaching this point.
The issue did not exist until the filter was changed along with a general service.
Would I need to possibly bleed the fuel line?
Any ideas would be really good!
Ta :)
Hi!
Thanks!
Ta :)
Jun 28, 2010 at 7:09 AM
