1987 Nissan Pathfinder Low Oil Pressure
PRICEMR
I have a 1987 Nissan Pathfinder, 4X4, vg30 engine, automatic trans. The motors were swaped with another vg30 engine with 94000 miles. After driving it for 2 days the oil pressure drops to 10 after it warms up. It has a new oil pressure sending unit, and just had a new oil pump put in it at the shop and still doing the same thing, oil pressure dropping off. I was wondering what else could cause this, The head gasket was changed, heads milled, and new timing belt pror to the engine change.
Aug 12, 2007 at 10:44 PM
  • 75,988 POSTS
[quote:4fa5474a69="pricemr"]I have a 1987 Nissan Pathfinder, 4X4, vg30 engine, automatic trans. The motors were swaped with another vg30 engine with 94000 miles. After driving it for 2 days the oil pressure drops to 10 after it warms up. It has a new oil pressure sending unit, and just had a new oil pump put in it at the shop and still doing the same thing, oil pressure dropping off. I was wondering what else could cause this, The head gasket was changed, heads milled, and new timing belt pror to the engine change.[/quote:4fa5474a69]
The only way to tell is to hook-up an oil pressure gauge and read off. Remember oil pressure increases when engine rpm increases.
@ 2K rpm it should read atleast 40lbs or better.
Did they prime the pump?
If its not the pump or sending unit its coming from bad engine bearings rod/crank
Aug 12, 2007 at 11:23 PM
Suggested Repair
Verify actual oil pressure with a mechanical gauge; it should be at least 40 psi at 2000 rpm and rise with engine speed. Confirm the new oil pump was primed. If the pump and sending unit are ruled out and pressure is still low, suspect worn rod or crankshaft bearings.
Conversation Summary
The owner of a 1987 Nissan Pathfinder with a swapped VG30 engine reports oil pressure dropping to about 10 when warm, despite a new oil-pressure sending unit and a new oil pump. The expert advises confirming the reading with a gauge, checking that the pump was primed, and considering worn rod or crank bearings if those parts are not the cause.
