I am trying to remove the water pump but the cranshaft keeps spining. How do I stop it from spinning
Nov 25, 2006 at 4:25 AM
To stop the crankshaft while removing the center bolt, use an air tool if available. Otherwise, have an assistant hold the flywheel with a flywheel wrench, or leave a manual transmission in gear. If the fan bolts are the issue, leave the fan belt in place so the fan cannot spin.
The owner of a 1991 Nissan Pathfinder could not remove the water pump because the crankshaft kept spinning. The expert assumed the center crankshaft bolt was the problem and suggested air tools, holding the flywheel with a wrench and an assistant, or leaving a manual transmission in gear. If the fan bolts were the issue, the fan belt should be left in place.
