1992 Nissan Pathfinder Left Signal On Brake
SHARKYMAUI
92 Nissan Pathfinder se v6 4x4 167,454
When I press the brake pedal, the left turn signal lights illuminate. Both brake lights work. The left turn signals work.
Dec 13, 2006 at 6:27 AM
BACKYARDMECHANIC
  • 337 POSTS
Are you referring to the outside lights or the one on the dash?
Backyardmechanic
Dec 13, 2006 at 6:56 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a ground problem.Could be under the dash or at the lights
Dec 13, 2006 at 9:45 AM
Suggested Repair
Check for a poor ground under the dash or at the lights, which can make the left turn signal lights illuminate when the brake pedal is pressed.
Conversation Summary
The owner of a 1992 Nissan Pathfinder said the left turn signal lights illuminate when the brake pedal is pressed, while both brake lights and the left turn signals otherwise work. One expert asked whether the dash or outside lights were affected. Another expert said it sounds like a ground problem under the dash or at the lights.
