Instrument panel not working
MIKEPIOTRASCHKE
  • 2000 NISSAN PATHFINDER
  • 6 CYL
  • 4WD
  • MANUAL
  • 82,000 MILES
The instrument panel goes out sometimes or gets stuck. No speedometer, odometer, radiator temp or fuel gauge. When driving it will fade out with the needles for the speedometer staying at what speed I was going, same for tach, fuel gauge. Also happens when first starting up the car, but gauges are all not registering, stay @ 0.
It seems to happen when it gets hot. No other problems when this happens. Car drives fine, all other instruments work, lights, ac, radio. When car sits in garage or overnight all is ok when starting up the next day.
Saturday, June 28th, 2008 AT 6:04 PM
KHLOW2008
  • 41,814 POSTS
Hi mikepiotraschke,
This is common you have an instrument cluster that is going out I would remove it and look for used one you can find them on eBay
Here is a video showing what you are in for when doing the job.
https://youtu.be/_HEC44xENxw
Please let us know what you find.
Cheers
Sunday, July 6th, 2008 AT 3:15 AM
