1987 Nissan Pathfinder air flow meter
195,000 MILES • 6 CYL • 4WD • MANUAL
IANSROSS
what causes a air flow meter to foul out, (resister seperated from attach point) car will not rev pass 3000 rpm, hesistates/ bogs out, i got a reading for air flow meter, replaced it, now the new one looks just like the old one (took only minutes to destroy new air flow meter)
Oct 25, 2010 at 10:24 AM
SERVICE WRITER
  • 9,123 POSTS
What is upstream of the meter?
What do the walls of the air passage to and from the meter look like? contaminated, clean?
Any signs of oil?
What does the air filter look like?
IS it a "performance" or oil saturated filter?
Oct 25, 2010 at 11:20 AM
IANSROSS
sorry meter was the wrong word, i had the car put on a diagnostic machine, and it came up as the air flow meter (it actually said it on the screen) when i removed it i saw that it was actually broken, there is no sign of oil, car actually runs better with the air flow meter disconnected but still bogs out, the air filter is a standard one
Oct 25, 2010 at 1:07 PM
SERVICE WRITER
  • 9,123 POSTS
Glad you figured it out. A code descrption does not mean a particular part is bad.
Oct 25, 2010 at 1:22 PM
IANSROSS
i understand what your saying about the code, what i don't understand is what could be causing the air flow meter itself to come apart at the point where it should be sodderd together, it was solid when i installed it, any idea ?
Oct 25, 2010 at 1:36 PM
SERVICE WRITER
  • 9,123 POSTS
Defective part, poor quality control. Was it a remanufactured one?
I've seen my share of parts that were bad right out of the box.
Oct 26, 2010 at 9:55 AM
IANSROSS
yes it is a remanufactured unit, its made by python, probly junk, do you know of any other manufacture
Oct 26, 2010 at 10:36 AM
SERVICE WRITER
  • 9,123 POSTS
a1-cardone is usually good. Ideally a new one is the best bet.
Oct 27, 2010 at 2:02 AM
