Knock sensor location
TIKIBABY13
  • 1997 NISSAN PATHFINDER
  • 6 CYL
  • 4WD
  • 83,000 MILES
Where is the knock sensor located at?
Thursday, April 9th, 2009 AT 10:21 PM
The knock sensor is under the intake manifold, here is the instructions on how to change it out in the images below. Please let us know if you need anything else to get the problem fixed.
Friday, April 10th, 2009 AT 12:03 AM
ARMYDAD
  • 1996 NISSAN PATHFINDER
  • 6 CYL
  • 4WD
  • 102,598 MILES
Where is the knock sensor located on my vehicle?
Thursday, May 23rd, 2019 AT 5:41 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
The knock sensor is located under the intake manifold between the cylinder heads. Here is the location
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1439.jpg
Here is a better view (below)
Cheers
WLIPS01
  • 6 CYL
  • 160,000 MILES
How do I locate and replace the knock sensor?
Knock Sensor On top rear of engine
https://www.2carpros.com/forum/automotive_pictures/12900_ks_27.jpg
WMROCZKA
  • 1998 NISSAN PATHFINDER
1998 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic
I am getting fault code for knock sensor failure.
The Haynes manual says it is located under intake plenum. I have removed it and cannot find any sensors under it or wires going to any sensors.
Where else could it be located?
Thursday, May 23rd, 2019 AT 5:42 PM (Merged)
Knock Sensor
ECCS Component Parts Location
https://www.2carpros.com/forum/automotive_pictures/12900_k_3.gif
https://www.2carpros.com/forum/automotive_pictures/12900_k1_1.gif
Engine Control Component Part Location
https://www.2carpros.com/forum/automotive_pictures/12900_k2_1.jpg
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
