electrical problem
NISSAN
JCHARRIS
1993 Nissan Sentra 1.6 77,000 miles,
during periods of rain the radio will turn off then on again, at the same time radio is off the drivers side window will not work. Power loss is intermittent and length of power outage changes.
Oct 26, 2007 at 9:11 AM
  • 75,988 POSTS
You might want to check the condition of your battery and its connections. Also could be the ignition switch is failing/relays/circuit breaker acting up.
Oct 26, 2007 at 9:29 AM
