1998 Infiniti I30 Check Engine Light
NISSAN
JESSEMDAILEY
How do you turn the check engine light off on a 1998 Infinity I-30? The code reads a 440 stating that emisson system malfuction. My gas cap seals do you have any ideas?
Mar 2, 2007 at 3:13 AM
  • 75,988 POSTS
[quote:aa163f29f9="jessemdailey"]How do you turn the check engine light off on a 1998 Infinity I-30? The code reads a 440 stating that emisson system malfuction. My gas cap seals do you have any ideas?[/quote:aa163f29f9]
To clear code you need a scantool
The Evap system is leaking-it needs leaking detection device to find it.
Mar 2, 2007 at 5:31 AM
Suggested Repair
Clear the code with a scan tool. The EVAP system is leaking and needs a leak detection device to locate the leak.
Conversation Summary
The owner of a 1998 Infiniti I30 has a check engine light with code 440, described as an emission system malfunction, and says the gas cap seals. The expert says a scan tool is required to clear the code and that the EVAP system is leaking and needs a leak detection device to find the leak.
