1996 Infiniti I30 Cold Stall P0125
MJHAYMORE
I have a '96 Infinity I30 (same engine as Nissan Maxima) w/ ~150,000 miles that has been stalling regularly while driving. It usually occurs when I am coming to a stop and have let off the gas. It never occurs after the engine has completely warmed up, it usually occurs soon after I have started driving. Then the car either cuts out completely, or the RPM's fluctuate up and down like it is starving for gas and then either recovers or stalls. The engine code P0125 "insufficient coolant for closed loop fuel control" comes up. It has been reset and has come on again. The thermostat has been replaced and I am about to replace the coolant temp sensor, but it doesn't seem like just the sensor would cause the stalling. Usually it starts up fine, but occasionally is takes several minutes and lots of cranking to get it going. Any ideas/suggestions would be appreciated. Thanks!
Mike :?
Feb 13, 2007 at 6:31 AM
2CARPRO JACK
  • 11,533 POSTS
Actually the coolant sensor can do things like that. Part of fuel control is knowing what temp the engine is at, if the coolant sensor is out of range then the PCM may think the engine is warm when it is cold, which would give a lean mixture
Feb 13, 2007 at 11:49 PM
Suggested Repair
Test and replace the engine coolant temperature sensor if it is out of range. An incorrect reading can make the PCM treat a cold engine as warm and command a lean mixture, causing cold stalling and code P0125. The thermostat has already been replaced.
Conversation Summary
A 1996 Infiniti I30 with about 150,000 miles stalls or surges when slowing after a cold start, and code P0125 returns after being cleared. It starts hard occasionally but runs better once fully warm. The thermostat was already replaced. The expert explained that a faulty coolant temperature sensor can make the PCM think the engine is warm when it is cold, producing a lean mixture and stalling.
