1988 Nissan Pulsar NX Check Engine Surge
They became easier to diagnose after 96 as all the connectors are now uniform as well as technical allocations. Before, like yours, each manufacture had their own way of doing things and made it very cumbersome.
Anyways, when you disconnect the battery, the computer loses it's memory and needs to be driven to re-learn it's data stream values so it can make necessary adjustments. When it finds the problem you have it will throw the light again. Sometimes the computer can use a "default"value for an input that is out of whack. An input would be a sensor for example the tell the computer what it sees, the computer makes an adjustment to fuel/air mix and the change is the result of the output. So there may or may not be codes stored in the computer. Best bet is to have it checked.
For what it matters, have heard of a fuel pressure regulator cuasing your condition as well as a computer that is grounding the EGR valve Too long, in which case the computer would need replacement.
Suggested Repair
Retrieve the OBD-I diagnostic codes and correct the rich-running condition. Check the fuel pressure regulator, and consider an ECU that may be holding the EGR valve grounded too long if codes and testing point that way. After a battery disconnect, drive the car so the computer can relearn before judging whether the fault returns.
Conversation Summary
A 1988 Nissan Pulsar NX surges around 250 rpm or 45 mph, will not accelerate past that, emits black smoke, idles roughly, sometimes stalls, and has inoperative temperature and fuel gauges when the check engine light is on. It sometimes runs normally with the light off, and disconnecting the battery temporarily restored normal operation. The expert explained that pre-1996 vehicles use manufacturer-specific OBD-I diagnostics, that a battery disconnect clears computer memory until the fault returns, and that a rich condition should be diagnosed promptly. Possible causes mentioned were a fuel pressure regulator or a computer grounding the EGR valve too long.
