2000 Other Nissan Models High Carbon Monoxide and Carbon Emi
2000 NISSAN
96,000 MILES • 4 CYL • 2WD • MANUAL
ANJANA
Car is EFI type. Already clear the plugs , Injectors and throttle body.
When it is drive, feel less pickup at low speed (Start up etc).
After the emission test
At 750 RPM – CO value (v/v) around 9 %
At 2750 RPM – CO value (v/v) around 1.5%
When I check the end of silencer can see high amount of carbon.
When accelerator push fast at once carbon partials can see at emission.
Carbon particles can see at Plugs 2-3 km runs after plugs clean.
Feel the fuel efficency is very less. Please help to Diagnose the issue.
Dec 28, 2009 at 5:11 PM
  • 75,988 POSTS
High CO
Carbon monoxide failures indicate an overly rich fuel mixture. On older carbureted engines without electronic feedback controls, look for things like a stuck choke, misadjusted or fuel saturated float or a rich idle mixture adjustment. On newer vehicles with electronic carburetors or fuel injection, the system may not be going into closed loop because of a bad coolant or oxygen sensor.
Dec 28, 2009 at 5:16 PM
