2007 Other Nissan Models starting
2007 NISSAN
98,000 MILES • 4 CYL • 2WD • AUTOMATIC
SAMAEN
i bought my versa brand new and i have been having this starting problem ever since. i try to start the car, and sometimes it starts perfectly. sometimes it takes 2-3 times to start. today it stopped starting all together! it only makes the "starting noise".
somebody told me it could be the fuel pump? but i understand that the fuel pump problem will kill your engine even while driving. should i check wires? starter? spark plugs ( which have never been changed) fuses? distributor? i'm sure it's not the battery..
Apr 4, 2010 at 8:18 PM
  • 110,194 POSTS
If it doesn't start, check for spark and fuel to the engine. One is most likely missing.
Let me know what you find
Apr 22, 2010 at 8:53 AM
SAMAEN
i had it towed into the dealership repair shop, and they told me the problem was the fuel pressure sensor?! it was dropping down to 20psi after a min.. so they replaced it for a total of $250.. now i guess it reads at 50psi.. but it still doesn't start sometimes right away and still sometimes has the long crank (sound when starts)
Apr 26, 2010 at 10:08 PM
  • 110,194 POSTS
I had a feeling it was fuel or spark related. If it is still hard to start and we know the pressure is good, then I have to ask when the last tune up was? Also, did they check the temp sensor?
Apr 26, 2010 at 10:30 PM
