2001 Other Nissan Models Ran out of gas, put gas in it and n
SHAWNDEBB2004
  • 2001 NISSAN
Engine Performance problem
2001 Other Nissan Models 6 cyl Wheel Drive Type unknown Automatic 106858 miles
I ran out of gas yesterday, got a gas can and put 5 gallons in it.I went to start it and the van won't start now?It's sounds like it wants to start but it does not! What would cause this? The gas gauage shows 1/2 tank.
Thursday, April 3rd, 2008 AT 9:09 AM
IRISHMOBILEMECHANIC
  • 10 POSTS
Im assuming your van is petrol, firstly you say you ran out of gas are you sure?Im not doubting you but could you have actually broken down whilst low on gas? Sounds like you did but you can try depressing gas pedal fully and turn engine over for 5 seconds then take foot of gas and crank it again without touching gas, the rush of air should start engine if it hjas flooded altough I do think you have actually broken down, have you checked cam, ignition etc?
Hope it helps. Regards irishmobilemechanic
Thursday, May 1st, 2008 AT 5:53 PM
