1974 Other Nissan Models Automatic Choke Relay
1974 NISSAN
22,000 MILES • 4 CYL • 2WD • MANUAL
BOBFOX
The Choke Relay switch on my 1974 Datsun 710 doesn't seem to be functioning correctly since there is no power going to the electrical wire that heats the choke. When I open it up there is a set of points that sit on top of a coil of wire. I can adjust the points but cannot find any information or specifications on how to set them or how wide the gap should be, or if the points should be touching to begin with. When they touch then there is current in the electrical wire that heats the choke. How can I adjust this Choke Relay? Any help would be much appreciated. Thanks! - John
Nov 9, 2008 at 11:50 AM
It should be touching -when it heats up for 3 minutes it will expand and separate the contacts
Nov 9, 2008 at 9:46 PM
BOBFOX
Thanks for your answer. By having the contacts touch, will that cause any drain on my battery or electic system?
Nov 10, 2008 at 6:42 AM
It shouldn't create battery drain when the ignition switch is off-if in doubt check it
Nov 10, 2008 at 6:45 AM
BOBFOX
Thanks! I'll check it out. I appreciate your help!
Nov 10, 2008 at 6:52 AM
