Nissan Np200 key with remote?
180,000 MILES • 1.6L • 6 CYL • 2WD • MANUAL
OMFABBLAM
I would like to know if I can get a key that have remote, to be coded to the immobilizer and also open the door locks? There is already an after market alarm, what I was thinking is,
if the alarm control be removed and only connect the door actuators, siren and motion sensor to the immobilizer. Is it possible for that to be achieved on the Nissan Np200?
Apr 8, 2026 at 6:04 PM
  • 55,694 POSTS
I have a couple of questions, for you, does the truck already have an alarm and electric door locks? If so they yes you can install a remote system to open the doors. The Avital 2103L is specifically sold as a keyless-entry system with two remotes, remote lock/unlock, flashing parking lights, ignition-controlled door locks, and auxiliary outputs. Let me know how the install goes. Ken
Apr 10, 2026 at 1:52 AM
OMFABBLAM
The Truck have an after market alarm system. My question is if I can remove the alarm system and connect the door locks to the immobilizer so I can use the remote that is on the keys. Because the alarm that was installed is not compatible with Nissan.
Apr 10, 2026 at 4:13 AM
  • 55,694 POSTS
Yes, the first step is to remove the after market alarm, find the alarm unit and trace the wires to remove/repair the stock harness. Then install the new remote lock system as the instructions depict. Please upload an image or a short video in your response of any problems, so I can see what's going on.
Apr 11, 2026 at 12:45 AM
OMFABBLAM
Hi, thanks for the information, I don't have a new lock system and I don't have a drawing. I want to use the old door lock, from the aftermarket alarm,
1. To use the motion sensor from the after market alarm
2. To use the horn from the after market alarm
3. To use the two door Lock from the after market alarm.
What I need, maybe a drawing on how or where to connect them for the New remote to be able to control them via the Immobilizer, after the remote is programmed to be recognized by the immobilizer, if it's possible.
Apr 11, 2026 at 2:14 AM
  • 55,694 POSTS
The new system you buy should have the instructions in it.
Apr 12, 2026 at 1:07 AM
