2004 Nissan Micra
ANGELA DI PALMA
  • 2004 NISSAN MICRA
Steering problem
2004 Nissan Micra 4 cyl Front Wheel Drive Manual
My daughter's car. She says at higher speeds(in third gear) the steering goes and she loses control.
Sunday, August 1st, 2010 AT 4:01 AM
  • 31,937 POSTS
Hi there,
Speed wobbles. Have the steering, suspension and tyres checked ASAP, you may have a dangerous failure ready to strike.
Mark (mhpautos)
Sunday, August 1st, 2010 AT 5:53 AM
ANGELA DI PALMA
Had the front end checked (steering, suspension, tires) and everything looked fine. He noted however, a nasty dent in the transverse frame (running from left to right at the front of the car). Probably caused by the accident she had. Could this cause the inability for the car to hold the road?
Tuesday, August 3rd, 2010 AT 12:33 AM
  • 31,937 POSTS
Hi there,
If all the suspension & steering are sound, may be there is a problem with the wheel alignment if you had an accident this cold well be out, go get a front wheel alignment check, this will show up any other front end problems.
Mark (mhpautos)
Tuesday, August 3rd, 2010 AT 4:16 AM
