1998 Nissan Maxima Speedometer Fails
DANJENKINS
1998 Nissan Maxima SE 118,000mi. When it is cold outside my speedometer and odometer work fine. But in the summer they do not work. Occasionaly the speedometer will jump up to my current speed but then it goes right back to zero. When the speedometer does not work the odometer does not roll, but when the speedometer does work the odometer will roll. Also, when the speedometer does not work the cruise control does not work, but when the speedometer works, so does the cruise control.
Jul 20, 2007 at 4:46 AM
  • 75,988 POSTS
[quote:f8b4d12d39="DanJenkins@woh.rr.com"]1998 Nissan Maxima SE 118,000mi. When it is cold outside my speedometer and odometer work fine. But in the summer they do not work. Occasionaly the speedometer will jump up to my current speed but then it goes right back to zero. When the speedometer does not work the odometer does not roll, but when the speedometer does work the odometer will roll. Also, when the speedometer does not work the cruise control does not work, but when the speedometer works, so does the cruise control.[/quote:f8b4d12d39]
Check the vehicle speed sensor on the transmission.
Jul 20, 2007 at 9:28 AM
Suggested Repair
Conversation Summary
On a 1998 Nissan Maxima SE, the speedometer and odometer work in cold weather but fail in summer, sometimes jumping to speed then returning to zero. Cruise control fails at the same time. The expert advised checking the vehicle speed sensor on the transmission.
