2001 Nissan Maxima Drag and High Idle
BUSHWICKTARHEELS
I have a 2001 Nissan Maxima with 84,000 miles on it.
I have 2 questions.
1. When I take my foot of the gas pedal and let the car "free wheel" I feel the car is solwing down like If I am gently pressing on the brakes although I am not. What could this be?
2. When I start the car I hear the engine rev up like if my foot was on the gas when i turn the key. It goes back to a normal state state but is that normal to reve up like that?
Apr 13, 2007 at 7:31 AM
  • 75,988 POSTS
[quote:8aec5aaeb8="bushwicktarheels"]I have a 2001 Nissan Maxima with 84,000 miles on it.
I have 2 questions.
2. When I start the car I hear the engine rev up like if my foot was on the gas when i turn the key. It goes back to a normal state state but is that normal to reve up like that?[/quote:8aec5aaeb8]
1. Caliper might be binding or the brake hose collapsed inside and acting like a one way check valve.
2. Its probably because the FICD is sticking maybe needs cleaning.
Apr 13, 2007 at 10:00 AM
BUSHWICKTARHEELS
Thank you very much.
Sorry to be so dumb but what is an FICD and how can i clean it?
If it is a caliper or a brake hose, it s that expensive to fix?
Apr 17, 2007 at 2:45 AM
  • 75,988 POSTS
The FICD-fast idle control device provides increase RPM during initial start-up and should shut-off within a few sec's. Something like toyotas cold start time switch to operate the cold start injector.
For the brakes-you need to have it all open-up to identify the problem-could be caused by the parking brake needing adjustment.
Apr 17, 2007 at 9:14 AM
BUSHWICKTARHEELS
thank you.
I will pay a visit to Strauss or Pep Boys
Apr 18, 2007 at 1:49 AM
Suggested Repair
Have the brakes opened and inspected for a binding caliper, a collapsed brake hose acting like a one-way valve, or a parking brake that needs adjustment. A brief high idle at startup can be normal from the fast idle control device (FICD); if it sticks, cleaning may be needed.
Conversation Summary
The owner of a 2001 Nissan Maxima with 84,000 miles reported that the car slows as if the brakes are lightly applied when coasting, and that the engine briefly revs high at startup before returning to normal. The expert said the drag could be a binding caliper, a collapsed brake hose, or a parking-brake adjustment issue that requires inspection. The startup rev was attributed to the FICD, which raises RPM briefly and may need cleaning if it sticks. The owner planned to take the car to a shop.
